Can some one please explain why JPG imports into ViaCad vary in resolution. Why for instance graphic that are perfectly sharp in a graphic app become unreadably fuzzy when imported?
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
Hi Bill When imported it converts the jpg into an OpenGL texture that is displayable in 3D. OpenGL has a max size it can handle, based on the board. It may be you are seeing a high res image scaled down into the max size of the board. To confirm this is the issue you are seeing, turn off Enable OpenGL in View: Shade Options. Tim
Thanks Tim There isn't an Enable OpenGL in my View: Shade Options. However I closed down Safari and a couple of other programs and managed to get an import that is sharp enough for what I want. I can see that this is going to be an interesting one to remember.
