Solid Modeling
Cant thicken an extruded solid.
                I have followed the tutorial of creating a snowboard to the letter. I have managed (finally lol) to come up with a surface that is kind of what I need and only now need to make a few adjustments.
When I go to thicken solid, I always get an error "Unable to thicken solid"
I have recreated the line that I am extruding many times just to make sure everything is joined etc, it extrudes, I remove the other solid just like the tutorial but then get the error.
I have attached a screenshot - can someone see what I am doing wrong?
Boyd
Edited by user  Monday, August 8, 2016 4:52:51 PM(UTC)
 | Reason: Not specified
boydage attached the following image(s):
(188kb) downloaded 24  time(s). You cannot  view/download attachments. Try to login or register.
                 Hi Boyd The most frequent error for thickening occurs when there is an area of local curvature that is greater then the offset amount. This means a valid offset is impossible because it would self intersect. Are you able to thicken at a very small amount?  Or how about a negative thickness value? (will offset the opposite side) Tim
    Tim Olson  IMSI Design/Encore
Solid Modeling
