Solid Modeling
Error with Skin Solid: Wires must be either all closed or all open
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
                I can successfully use the Skin solid tool, but when I scale the grouped wires a bit larger, then I get an error "Wires must be either all closed or all open". Strange, because when I scale the group only a bit larger, there is no problem. Only when  I do it even larger, suddenly the group is not closed. See video and attached file.
https://youtu.be/WwxGMs41ZqU This is both in ViaCad 8 and 9.
 Posthoorn 03.vc3
(1,963kb) downloaded 11  time(s). You cannot  view/download attachments. Try to login or register.
Solid Modeling
