Solid Modeling
Wireframe separating from object
I've noticed this behavior since v.8 and as it's quite random I can't tell if it's something I'm doing or a program fluke, but I don't think it's me.
Occasionally I find that an object has separated into the wireframe and solid. Both are still connected as selecting one also selects the other. Very often the wire frame has flown off to some location waaay off from where the solid is located. If it's a small part it's nearly impossible to find the errant wireframe.
In the attached screenshot I was working on adjusting some object positions and suddenly find the green plate and its wireframe separated.
Is there a way to merge them back together again? I haven't found one so usually have to delete the object and re-create.
Suggestions anyone?
Mats
Edited by user Tuesday, June 7, 2016 4:02:04 AM(UTC)
matso attached the following image(s):
(295kb) downloaded 24 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 175 times Was thanked: 158 time(s) in 108 post(s)
Hi Mats,
I've noticed you use a lot of strut drawings. I've found it easier if you
extrude a drawing, and then delete the outline, you will have less problems.
You probably have these links already to models and drawings, but just in case you don't.
http://www.cooperindustr.../cad-bolted-framing.html http://unistrut.us/index.php?WP=CAD3d Larry
(59kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks Larry,
Not sure what you mean by "strut drawings"... Are you referring to the strut channel profiles I use in my design and you may have seen on a previously attached file of mine? - This file does not have any strut channels, but square tubing...
Your suggestion to delete the outline/wire frame is ok, but I've found that until the design is final, the outline is required as I do a lot of tweaking until all my numerous objects are in the right place. Or possibly I don't understand the proper use of the outline/wire frame...
Thanks for the links. I get most of my cad files from
McMaster-Carr .
However, the original question remains - why does the outline separate from the solid?? And for no apparent reason.
Mats
Hi Mats, What I was referring to by strut drawings, was the unistrut channel and fittings that you use. Your assemblies are very well done, you should post them in the Gallery. When you move an object with an outline, and you don't select the entire object, including the outline, the object moves and the outline stays behind. Larry
Hi Larry,
Quote: When you move an object with an outline, and you don't select the entire object, including the outline, the object moves and the outline stays behind.
Not in my experience. Clicking on the object always selects the entire object. If there's a way to select a partial object, I haven't discovered it yet :-)
Selecting a surface face of an object is a partial object I guess, but that requires Solid Direct Edit tools. In this case I was using the standard black Selection arrow tool.
Quote: Your assemblies are very well done, you should post them in the Gallery.
Thanks! The design is proprietary, but maybe I can post some sections of it when complete.
Cheers,
Mats
Hi Mats,
This is an example of outline problems, that I have sometime.
http://www.screencast.com/t/E7gS4X9tkNo
Solid Modeling
