gjames
#1 Posted : Thursday, June 2, 2016 7:26:00 AM(UTC)
gjames
Was thanked: 4 time(s) in 1 post(s)
I am trying to convert a Mesh that was a STL import. I am running ViaCAD Pro v9 with PowerPack Pro.
I receive this error when trying to perform Mesh to Analytic (SubD to Nurbs is not enabled for this product) then I click OK and receive this error (Unable to convert mesh element into analytics).
I will attached the STL in question.
I will also attach a screenshot of my settings.
Please advise. Thanks.
Edited by user Thursday, June 2, 2016 7:29:26 AM(UTC)  | Reason: Not specified
STL and Screenshot.zip (400kb) downloaded 11 time(s).
#2 Posted : Thursday, June 2, 2016 10:17:06 AM(UTC)
Are you running ViaCAD Pro 64 out of the 64 bit folder? Some of the technology in PowerPack Pro requires using the 64 bit version of ViaCAD Pro.
gjames
#3 Posted : Thursday, June 2, 2016 5:57:01 PM(UTC)
gjames
I thought I was. I know I loaded it.
I just looked and cannot find ViaCAD in the 64-bit folder. Very strange.
I will dig further and try installing it again. I know I downloaded what you sent me and installed it.
BTW: for some reason I am not getting notifications via email for new posts on the forum.
gjames
#4 Posted : Thursday, June 2, 2016 6:03:00 PM(UTC)
gjames
I just tried to re-install ViaCADPro9_64_1198_NDRM.exe and the default install directory is: C:\Program Files (x86)\Punch! Software\ViaCAD Pro 9\
That is the 32-bit directory. My C:\Program Files path has no Punch or ViaCAD folders in it.
#5 Posted : Friday, June 3, 2016 1:03:32 AM(UTC)
Hi James
I made a Pro 64 build tonight based on the 1201 code stream and sent you a link. Let me know if this corrects the issue.
TIm
