Trendstyle Design
#1 Posted : Tuesday, May 17, 2016 4:07:37 PM(UTC)
Trendstyle Design
Hi does anyone no how I fix the Dimension witness line length? See attached working Drawing
also how do i attach a pdf?
3 FLOOR PLAN.pdf (3,044kb) downloaded 26 time(s).
Trendstyle Design
#2 Posted : Tuesday, May 17, 2016 6:42:57 PM(UTC)
Trendstyle Design
ok worked outhow to attach the pdf
L. Banasky
#3 Posted : Wednesday, May 18, 2016 5:01:04 AM(UTC)
L. Banasky
Was thanked: 150 time(s) in 103 post(s)
The Inspector is the place to control Dimension Properties.
I'm not sure about the witness lines, but this is the place to start.
Trendstyle Design
#4 Posted : Wednesday, May 18, 2016 6:39:45 AM(UTC)
Trendstyle Design
Hi L.Banasky thanks for your reply.
I try to keep all my dimensions the same length see attached
Can I create my owner dimension arrow?
Edited by user Wednesday, May 18, 2016 6:43:07 AM(UTC)  | Reason: Not specified
277 23-NOVEMBER-2011 SHEET 2.pdf (256kb) downloaded 13 time(s).
L. Banasky
#5 Posted : Wednesday, May 18, 2016 6:51:32 AM(UTC)
L. Banasky
I don't know if you can create your own, but there are plenty to choose from.
Arrow Format.jpg (45kb) downloaded 5 time(s).
Trendstyle Design
#6 Posted : Wednesday, May 18, 2016 3:24:58 PM(UTC)
Trendstyle Design
Thanks L.Banasky for your help.
Thats pretty much made up my mind about the program, it's great in some areas just lacks that little bit extra control that "I" like, it's close to what I wanted, but just not quite there yet.
I not sure if I'll continue with it at this stage
18 years experience in the Building Design & Drafting Architectural.
I use
Autosketch " Old Drafix" with House Rocket 18 Years.
Chief Architect 12 Years
Revit 4 Years
Archicad 4 years
Turbocad "Windows" 4 years
Drafsight 1 year
ViaCad testing
TurbocadMac Looking at?
Trying to replace Autosketch ?
#7 Posted : Wednesday, May 18, 2016 6:43:33 PM(UTC)
I use
Revit 4 Years
Archicad 4 years
Drafsight 1 year
ViaCad testing
I am not sure there was anymore control in auto sketch . Maybe you can explain what you want to control and we can help you.
#8 Posted : Wednesday, May 18, 2016 7:07:58 PM(UTC)
Hello
In the Inspector, dimension properties you can control the witness lines
Edited by user Wednesday, May 18, 2016 7:08:29 PM(UTC)  | Reason: Not specified
Trendstyle Design
#9 Posted : Wednesday, May 18, 2016 7:19:41 PM(UTC)
Trendstyle Design
Yes manually each time but I'm talking about automatically for rows of dimensions see attached
Trendstyle Design attached the following image(s):
Capture DIMENSION WITNESS LINES EXTEND THE SAME AMOUNT WITHOUT EDITING EACH ONE.PNG (82kb) downloaded 8 time(s).
Trendstyle Design
#10 Posted : Wednesday, May 18, 2016 7:47:28 PM(UTC)
Trendstyle Design
Hopefully this will explain what I'm trying to do.
Capture DIMENSION WITNESS LINES EXTEND THE SAME AMOUNT WITHOUT.pdf (1,642kb) downloaded 11 time(s).
Trendstyle Design
#11 Posted : Wednesday, May 18, 2016 8:14:43 PM(UTC)
Trendstyle Design
see attached jpeg
Capture DIMENSION WITNESS LINES EXTEND THE SAME AMOUNT WITHOUT EDITING EACH ONE.PNG (292kb) downloaded 18 time(s).
24c
#12 Posted : Thursday, May 19, 2016 1:22:28 AM(UTC)
24c
Was thanked: 50 time(s) in 37 post(s)
Hi Trendstyle Design
The problem as I see it is your selection of the endpoint for your dimension.
If you look at this picture, if I click on the endpoints of the line at the bottom I get long witness lines, but if I click on the bottom and drag up to a common intersect position they are all maintained the same...so you need to maintain a consistent reference position for your dims, essentially translating the vertical drops into a horizontal equivalent, by plotting the intersections.
I hope this makes sense, but I did this sketch with no mods to tolerances or otherwise.
Using SharkFX, but it should be the same in ViaCAD
Mike
PS Is this your normal drawing style? I only ask, and not being rude, as it looks a tad "cluttered" to me, but I'm no architect. :)
Edited by user Thursday, May 19, 2016 1:29:59 AM(UTC)  | Reason: Not specified
24c
#13 Posted : Thursday, May 19, 2016 2:54:43 AM(UTC)
24c
Hi again, Trendstyle Design,
OK, I played with the tolerances and values, and this is pretty clean, and I think follows what you're trying to do with the annotated picture.
Settings as per boxes, and I thought the DIN setting seemed cleaner than ANSI
Hope this helps, but I learnt something from your query, so thanks for the question. :)
Mike
Trendstyle Design
#14 Posted : Thursday, May 19, 2016 7:36:32 AM(UTC)
Trendstyle Design
Mike
Hi Mike Thanks for your imput.
Yes this is pretty much it. The one I have shown as an example is from the building company I'm doing work for. But they are all very similar through out WA.
We don't use large format prints that often (Mainly because the Local shires & Builders prefer A3 size sheets) Some even specifically requesting the smaller format. So this means Cramped Cluttered Drawings with notes wherever you can fit them and lots of sheets. This is why I need to keep the Witness lines at a set distance :-).
Thanks again Joe
PS I agree about them being cluttered.
Edited by user Thursday, May 19, 2016 7:39:33 AM(UTC)  | Reason: Not specified
MaiFy
#15 Posted : Thursday, May 19, 2016 8:18:10 AM(UTC)
MaiFy
Hi there
On the version I am using there are some additional settings in the standards manager that may be useful.
Hope this helps
Shark standards.jpg (273kb) downloaded 26 time(s).
Trendstyle Design
#16 Posted : Thursday, May 19, 2016 5:54:55 PM(UTC)
Trendstyle Design
Originally Posted by: MaiFy Go to Quoted Post
Hi there
Hope this helps
Thanks I will try that and see if ViaCad is the same
Edited by user Thursday, May 19, 2016 5:57:17 PM(UTC)  | Reason: spelling
Trendstyle Design
#17 Posted : Friday, May 20, 2016 4:24:19 AM(UTC)
Trendstyle Design
Hi there
Hope this helps
Just tried it could not get it to work still the same issue.
24c
#18 Posted : Friday, May 20, 2016 5:06:21 AM(UTC)
24c
Hi Trendstyle Design.
Did my workaround not work?
I was able to get the witness lines were a lot shorter, and I did away with the very long ones too by creating intersection points. for the dimension start & end positions.
Mike
Trendstyle Design
#19 Posted : Friday, May 20, 2016 9:25:19 AM(UTC)
Trendstyle Design
Mike
That will work but it will take too long. I'll keep testing it for a better way.
thanks
Joe
Guest (13)
