this is the snapshot of my screen:
anyone have this problem?
Edited by user Monday, April 11, 2016 1:35:46 PM(UTC)
martino attached the following image(s):
(474kb) downloaded 51 time(s). You cannot view/download attachments. Try to login or register.
Hello Martino I've had another user report this as well. I have not been able to reproduce. Do you happen to have steps to reproduce? Tim
Thanks: 224 times Was thanked: 177 time(s) in 107 post(s)
Originally Posted by: martino this is the snapshot of my screen: anyone have this problem?
See mine too...
(206kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: jlm Originally Posted by: martino this is the snapshot of my screen: anyone have this problem?
See mine too...
Using Build 1188 I have had this problem as well. There seems to be multiple copies on top of copies of the bounding box for drawings.
Often it goes away when I drag-select over it. But zooming in and out does not make it go away.
*It just happened.. when it occurred, I copied some geometry, went to a new layer to make my drawing and pasted it in the new draw view. First the geometry still continued to show even though I hid that layer. After drag-selecting, it went away (refreshed?). Then as soon as I enlarged the draw view, it left a ghost view behind as you can see. It also ghosted it when I moved the draw view window.
Edited by user Thursday, April 14, 2016 8:40:03 AM(UTC)
(29kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
And now this is happening - merely moving the draw view creates duplicates that only go away with a drag-select. Seems like a simple problem actually, so maybe it can be fixed easily..
(41kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Previously I had the same problem. Now with b1195 I cannot repeat. But I will keep an open eye !!
Edited by user Thursday, April 14, 2016 9:00:27 AM(UTC)
1 user thanked Jean-Francois Jacques for this useful post.
>>Seems like a simple problem actually, so maybe it can be fixed easily.. Unfortunately I have not been able to repeat this one yet. Something to do with moving or resizing the draw views on mac. Tim
Originally Posted by: Tim Olson >>Seems like a simple problem actually, so maybe it can be fixed easily.. Unfortunately I have not been able to repeat this one yet. Something to do with moving or resizing the draw views on mac. Tim
It doesn't happen that often, and is more of a minor nuisance than a workflow problem. I wasn't even going to mention it if no one else did. Hopefully its all gone in the next build as Jean-Francois suggested it might be.
I experienced this problem as well sometime last year. It was very annoying.
It appears to have been fixed in a subsequent update as I have not seen it for a long time.
In Draw View, random frame view outlines and other random junk often appeared on the screen. Only way to get rid of it was to close the file and reopen. The junk appeared not to be on the drawing itself as zooming in/out left the junk in place while the drawing objects scaled up/down.
Cheers,
Mats
Edited by user Saturday, April 16, 2016 2:30:34 AM(UTC)
Originally Posted by: matso I experienced this problem as well sometime last year. It was very annoying. It appears to have been fixed in a subsequent update as I have not seen it for a long time. In Draw View, random frame view outlines and other random junk often appeared on the screen. Only way to get rid of it was to close the file and reopen. The junk appeared not to be on the drawing itself as zooming in/out left the junk in place while the drawing objects scaled up/down. Cheers, Mats
I found that I didn't have to close the file. When I click-dragged over the junk it disappeared albeit temporarily. It would sometimes reappear when I dragged a new draw-view over to move its location, or even tried to expand a draw-view window. However I also have not seen it since I upgraded to the newest build last week.
Yes Mats, I confirm the same points.
