2D Drafting
How to center gripper in this case?
Thanks: 103 times Was thanked: 20 time(s) in 15 post(s)
Is this a bug or am I doing something wrong?
I'm having some trouble trying to get the Gripper to be centered among the selected points as shown in the attached image.
I tried both "Center of Selected" and "User Positioned > Reset Axis".
Here, i just want to use the griper to transform the selected points not the whole thing. If I scale from its current location it won't be a symmetrical operation.
I'm sure I can simply find the center and reset the axis to that, but I thought maybe the gripper would automatically calculate the center point of the selected. Would be easier especially for irregular shaped selections that don't have a line of symmetry.
Edited by user Wednesday, April 13, 2016 1:02:01 PM(UTC)
(63kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
which build do you use? here with build 1195 gripper is automatically positioned at center of selected points
(48kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
That started happening around build 1186, not sure which build fixed it but it is defiantly a build related issue.
Originally Posted by: rokoko which build do you use? here with build 1195 gripper is automatically positioned at center of selected points
Well I'm currently using build 1188, but I wasn't aware there is a new build. Do you know where can I download it from?
Thanks!
I suspect you have a polyline in the image where the gripper does not average the additional selected points.
We need to update the gripper logic to support multiple selects from a single polyline. Same for splines I believe.
Edited by user Thursday, April 14, 2016 11:03:54 AM(UTC)
2D Drafting
