Solid Modeling
Modeling and rendering a wire mesh
I'd like to model a
dome shape formed (stamped) from a wire mesh.
And I'd like to make a convincing hi-res rendering of it.
What is the best way to do it?
The mesh in its flat form is shown in the attached photo.
Thanks.
Mark
G2Art attached the following image(s):
(18kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Hi Mark Do you need the actual 3D geometry or just a final rendering? You might be able to make a texture or decal. Tim
Hi Tim, I need a rendering - but a really good one. I use KeyShot. Also - my image is low res but I could search for a better one. Mark
Thanks: 224 times Was thanked: 177 time(s) in 107 post(s)
Originally Posted by: G2Art Hi, I'd like to model a dome shape formed (stamped) from a wire mesh. And I'd like to make a convincing hi-res rendering of it. What is the best way to do it? Thanks. Mark
Hi Mark,
It reminds me of a "braided" pattern we had to model on a conical surface.
After many attempts with Shark, Rhino, T-spline, we finally made it in SolidWorks and re-imported the surface in SFX...
JL
(133kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Jim, Your model looks great and thanks for your reply. I'm looking for a simple solution to my problem. I don't have much time for experimentation before my deadline. Mark
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
1 user thanked Antoine for this useful post.
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi Mark,
i don't know if i understand it correctly, do you want to have a dome which looks like built from a grid, or should it have a fine braided mesh as surface such as antoine´s keyshot link?
(949kb) downloaded 18 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked defkon for this useful post.
Thanks, Antoine, that's really great and it's exactly what I'm looking for. I hope I can find it in Keyshot cloud. Mark
Hi Defkon,
Actually more like your dome or perhaps a cross between yours and Antoines.
Would you mind emailing your sfx file to me at
mark@g2art.com ?
Thanks.
Mark
A dome pressed from rectangular mesh will be m x n cartesian rather than radial, IMO. I think the viewpoint will dictate how much you can get away with.
Edited by user Tuesday, April 12, 2016 4:26:58 PM(UTC)
sieve mesh.sfx
(194kb) downloaded 12 time(s). murray attached the following image(s):
(167kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked murray for this useful post.
Thanks, I think you're right. I'll take a look at that. Mark
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
Can't you map a mesh image to a dome shape in Keyshot?
Craig attached the following image(s):
(156kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
3 users thanked Antoine for this useful post.
Hello,
Here my demo with Keyshot and opacity map.
http://www.screencast.com/t/Bs5sAJkR Antoine
modeled with SharkFX but ok, ok it's no correct but funny :)
Antoine
Edited by user Wednesday, April 13, 2016 6:37:47 AM(UTC)
Antoine attached the following image(s):
(437kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
Solid Modeling
