ViaCad v9
When I import some DWGs I get unwanted dimension info that shows in the drawing in a very large font.
This dimensioning info does not show in any other Cad program or Viewer that I've opened it with.
I have attached pictures of the result I get and the way it should look.
Thanks for any guidance. Regards, Tom
pol32 attached the following image(s):
(137kb) downloaded 26 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked pol32 for this useful post.
If you can private email the file i can take a look. Thanks Tim
Hi Tom
We have made the updates below to support your DWG file.
--Updated text and dimension attribute scaling when inserted as part of a scaled block
--Provide support for a block where elements of the block are in different layers
--Correction for DWG text objects with one character
--Updated Concept Explorer and drawing code for objects in a block with different layers
It looks like the graphic symbol for the company logo is an OLE graphic object which we do not support.
These changes will be in the next beta build (1195).
Many thanks for sending the file! Before your example file, I was not aware elements in blocks could be in separate layers.
Edited by user Tuesday, March 29, 2016 2:54:27 PM(UTC)
(248kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Hi Tim, Thanks for looking into this. How would I get the beta build? Regards, Tom
I will post a notice in the forum when it is ready. Tim
Hi Tim,
I tried out v1195 and I still see import errors.
Regards, Tom
(219kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 230 times Was thanked: 182 time(s) in 110 post(s)
Hi Tom,
I get a lot of these errors too with build 1201.
I'll send my file to Tim...
(299kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
