2 Pages<12
solardrifter
#21 Posted : Tuesday, March 15, 2016 3:52:32 PM(UTC)
solardrifter
For me it doesn't work well. No matter where I select the splines or the line, the result is always the red circle on the picture.
I'm using FX9 1192 on Win7
George
solardrifter attached the following image(s):
tri tangent circle.JPG (83kb) downloaded 11 time(s).
Art Smith
#22 Posted : Tuesday, March 15, 2016 4:05:20 PM(UTC)
Art Smith
George-
thanks for posting your input!! that's two of us.....
it would be great to hear from the other two forum users that downloaded the file.
Art
[email protected]
Edited by user Tuesday, March 15, 2016 6:48:00 PM(UTC)  | Reason: Not specified
#23 Posted : Tuesday, March 15, 2016 4:10:12 PM(UTC)
I'll ask one of the guys in Encore QA give it a try with 1192.
Art Smith
#24 Posted : Thursday, March 17, 2016 3:28:39 PM(UTC)
Art Smith
Art
What is your Snap Hit Radius set at? (Under prefs)
Tim-
is "6" good, bad, in the tested/verified range, .........?
what's the word from Encore?? they've had two days! more importantly, when will a tested/verified Three Tangent Circle tool update for 1192 be available? I'm dead in the water until there's a Three Tangent Circle tool that works with splines.
Art
[email protected]
#25 Posted : Friday, March 18, 2016 10:17:14 PM(UTC)
It failed for them as well. I'm private emailing you an installer with a hot fix from Spatial/ACIS that corrects the problem.
Art Smith
#26 Posted : Saturday, March 19, 2016 2:43:33 PM(UTC)
Art Smith
Tim -
SharkFX9_1193_SP3_R25_ESD is a major step forward in resolving the problems with the Three Tangent Circle tool, but I'm guessing there's still work to be done. most importantly, the desired circle can now be drawn with the Three Tangent Circle tool in both the cases in my project. that said, the "Vertex" (ie: tangent) can only be located/selected on one side of each circle ignoring the tangent point to the line. on the other side of one of the circles the only point that can be located/selected is labeled "Intersect"; on the other circle nothing can be located/selected in the vicinity of tangent point. in the near term, the Mirror tool can be used to establish the missing "Vertex" (aka: tangent) as required.
the seemingly anal preoccupation with selecting the exact "Vertex"/tangent point is being driven by the required future use of multiple curves dictated by the Loft Surface tool. imposing common location and slope at the mating ends of all of the curve segments will hopefully avoid the problems encountered during a previous attempt at using trial & error derived approximate tangent points (ie: R to four places to the right of the decimal point).
Art
[email protected]
ps: have you identified what "extra's" you have installed or preferences that enabled you to make the posted Three Tangent Circle tool video with 1192 while the rest of us couldn't make it work?
Edited by user Saturday, March 19, 2016 2:48:24 PM(UTC)  | Reason: Not specified
three tangent circle Major progress.jpg (71kb) downloaded 5 time(s).
#27 Posted : Saturday, March 19, 2016 7:03:12 PM(UTC)
Hi Art
Using the build I sent you, I am able to find all four case. Video below showing the locations I picked.
http://www.csi-concepts.com/Demo/videos/threeTangent.swf
Art Smith
#28 Posted : Saturday, March 19, 2016 7:58:32 PM(UTC)
Art Smith
Tim-
agree! what I can not yet locate/select is the "Vertex" (ie: tangent point) on both splines (only one)............ the tangent point is crucial for creating/trimming curves with matching ends (both location and slope). given my limited experience with the Loft Surface tool, it gets very unsociable with anything other than perfectly matching curves.
Art
[email protected]
Guest (11)
2 Pages<12
