Thanks: 15 times Was thanked: 31 time(s) in 27 post(s)
I'm not talking about Model to Sheet here, is there a way to flatten a perspective view? Normally I would just export to Illustrator format but I wonder if there is a shortcut since I want the flattened view to stay inside SharkFX. Thanks in advance Claus
Thanks: 2 times Was thanked: 32 time(s) in 26 post(s)
Hello Claus,
Easy !!
But.....
when you select the model, the wireframe display disappears hidden edges.
http://www.screencast.com/t/YNanPNfub Antoine
1 user thanked Antoine for this useful post.
Thanks Antoine, I was hoping for a way to keep the hidden lines hidden. I know I can just export the isometric view to Illustrator which will flatten it but often splines get messed up in the process. Maybe I should propose a sort of "take vector snapshot" tool... Claus
