bongoboy
#1 Posted : Tuesday, March 15, 2016 6:38:44 AM(UTC)
bongoboy
Hi there,
I'm trying to use the Model to Sheet tool. The only line "method" that is available is "Polyline" which facets the lines in the sheet.
I thought there was a spline option to maintain smooth curves? Little help?
I'm using ViaCAD Pro 9 on a PC Windows 10
L. Banasky
#2 Posted : Tuesday, March 15, 2016 8:12:13 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
You don't have this enclosed option selection when you select Model To Sheet?
Model To Sheet.jpg (41kb) downloaded 9 time(s).
bongoboy on 4/18/2016(UTC)
#3 Posted : Tuesday, March 15, 2016 10:29:23 AM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Precise Curves is in Shark LT and Shark FX. Precise Curves is based on the CATIA V5 Hidden Line Component which Encore licenses additionally.
bongoboy
#4 Posted : Monday, April 18, 2016 9:20:24 AM(UTC)
bongoboy
Thanks for the info. I thought I was going crazy.
