2D Drafting
Model to Sheet - Polylines
Hi there, I'm trying to use the Model to Sheet tool. The only line "method" that is available is "Polyline" which facets the lines in the sheet. I thought there was a spline option to maintain smooth curves? Little help? I'm using ViaCAD Pro 9 on a PC Windows 10
Thanks: 200 times Was thanked: 164 time(s) in 113 post(s)
You don't have this enclosed option selection when you select Model To Sheet?
(41kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked L. Banasky for this useful post.
>>I thought there was a spline option to maintain smooth curves? Little help? Precise Curves is in Shark LT and Shark FX. Precise Curves is based on the CATIA V5 Hidden Line Component which Encore licenses additionally. Tim
Thanks for the info. I thought I was going crazy.
2D Drafting
