2D Drafting
"points" on ends of lines, arcs...
I am suddenly getting points showing on the ends of lines, arcs. When I box select them, they turn red, but cannot be deleted. Further to that, when I delete the line, I am left with a ghost line and point(s) which disappears if I start to box select it. I don't remember changing any settings/preferences. Any ideas? Vcad2d3d v9 build 1109. Regards, Ian Kirby. NSW Australia
Ian Kirby Wollongong Australia
Was thanked: 523 time(s) in 358 post(s)
Hi Ian Check the state of your Edit : Show Points. Also you might want to consider updating to 1184. Rename you current version as backup. Tim
Hi Tim, Many thanks; the "show points" was on, don't know how/when it happened, but now sorted. I'm still getting the ghostly image (about half-regular line-weight) of items I delete, but when I try to drag select them, they disappear in front of the dragging box. Regards, Ian Kirby. NSW Australia
>>I'm still getting the ghostly image (about half-regular line-weight) of items I delete, but when I try to drag select them, they disappear in front of the dragging box. You might want to try the update. Tons of fixes since 1109. Save your current version (add 1109 to name/folder), and from within ViaCAD click Help : Current Version to receive the free update. Tim
2D Drafting
