ianjkirby
#1 Posted : Monday, March 14, 2016 9:10:57 PM(UTC)
ianjkirby
I am suddenly getting points showing on the ends of lines, arcs. When I box select them, they turn red, but cannot be deleted.
Further to that, when I delete the line, I am left with a ghost line and point(s) which disappears if I start to box select it. I don't remember changing any settings/preferences. Any ideas?
Vcad2d3d v9 build 1109.
Regards, Ian Kirby.
NSW Australia
Ian Kirby
Wollongong Australia
#2 Posted : Monday, March 14, 2016 10:24:07 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Hi Ian
Check the state of your Edit : Show Points. Also you might want to consider updating to 1184. Rename you current version as backup.
ianjkirby
#3 Posted : Monday, March 14, 2016 10:33:04 PM(UTC)
ianjkirby
Hi Tim,
Many thanks; the "show points" was on, don't know how/when it happened, but now sorted.
I'm still getting the ghostly image (about half-regular line-weight) of items I delete, but when I try to drag select them, they disappear in front of the dragging box.
Regards, Ian Kirby.
NSW Australia
Ian Kirby
#4 Posted : Monday, March 14, 2016 10:56:24 PM(UTC)
You might want to try the update. Tons of fixes since 1109. Save your current version (add 1109 to name/folder), and from within ViaCAD click Help : Current Version to receive the free update.
