javg
#1 Posted : Friday, March 11, 2016 3:01:46 AM(UTC)
javg
I installed the updat for ViaCAD V9. So I now hve 1184 (my former version was 1104).
I found out that the print problem, already observed and brought on the forum a couple of months ago, still does not work properly.
Still the part in Gourad is sgown on the printed paper is "a big grey blurg", high and not in the place of the sheet.
I did hope that this very old problem was finely solved.
javg
#2 Posted : Friday, March 11, 2016 5:19:27 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Javg
I thought we made some corrections for this. Would you be able to email/attach the part with your print layout defined?
javg
#3 Posted : Tuesday, March 15, 2016 4:06:04 AM(UTC)
javg
Tim,
Iwold like to enclose the ViaCAD-V9-file.
In this you will find a simple exemple, a spanner.
In the sheet in Gourad.
Printing result in a blurb of that vieuwport in gray on paper.
I have also printed the result in a PDF-file, so yoy can see the result.
ViaCAD _DH.vs04.Test.01.PDF-writer.150316.pdf (451kb) downloaded 13 time(s).
javg
#4 Posted : Thursday, March 17, 2016 3:25:50 AM(UTC)
javg
Tim,
Again trying to get some examples of the printing-problem to you.
I have set up a simple block (100x100x100 mm) is a ViaCAD-file.
And also produced 1 sheet of the product.
You can see the iso-view in Gourad.
Printing the sheet with CutePdf-writer or on paper produced the strange "grey-blurb" on the place of the iso-view.
DH.vs05.Test.02.170316.vc3 (39kb) downloaded 9 time(s).
Sheet.DH.vs05.Test.02.inPDF.170316.pdf (19kb) downloaded 14 time(s).
#5 Posted : Thursday, March 17, 2016 12:47:15 PM(UTC)
Hello Javg
I just private emailed you a new ViaCAD3D.exe for build 1193 to confirm that this is now corrected.
javg on 3/18/2016(UTC)
javg
#6 Posted : Friday, March 18, 2016 8:41:37 AM(UTC)
javg
I have received your email for the fix of the printing problem.
I look for some time to fix it by the way mentioned in your mail.
But probebly I will wait for the full install you announced in the mail.
Nevertheless: many thanks for the quick reply and fix.
javg
