Brian Carter
#1 Posted : Friday, February 12, 2016 10:29:40 AM(UTC)
Brian Carter
I've used the standards manager for setting up my DIM style, but the dimension style keeps reverting to ANSI every time that I save or switch tools. Anyone have an idea what might be causing this? It is not a major problem, but frustrating.
Brian
#2 Posted : Friday, February 12, 2016 3:38:33 PM(UTC)
Was thanked: 523 time(s) in 358 post(s)
Hi Brian
Is it possible that something is selected? If something is selected, it does not set the default.
Brian Carter
#3 Posted : Tuesday, February 16, 2016 8:50:55 AM(UTC)
Brian Carter
Hi Tim,
I am pretty familiar with ViaCAD and have made sure that nothing else is selected. This issue has only arisen since i moved to Build 1184. Thanks again for your help.
Brian
