Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Does ViaCad Pro support 2d igs curves ? I tried importing some that imported fine in rhino but didn't come through on Viacad.
via_blank.igs
(32kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Was thanked: 523 time(s) in 358 post(s)
>>Does ViaCad Pro support 2d igs curves ? ViaCAD Pro IGES supports curves. Can you send me an example file not working? Tim
Sorry I didn't know how to attach files and wound up attaching it to my last post.
They are coming in as white. If you have a white background you might miss them as I first did.
Edited by user Friday, January 29, 2016 12:37:36 PM(UTC)
They come in as two little lines. Attached is a PDF showing what it should be.
Untitled 1.pdf
(59kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: solidtooldesigns They come in as two little lines. Attached is a PDF showing what it should be.
Ahh it's a polycurve! Using your example I was able to add support for this curve type (I explode into individual curves). The change will be in 1186 builds.
This impacts not just IGES, but other importers such as STEP, SolidWorks, SolidEdge, CATIA, NX, etc.
Many thanks for taking the time to post the example file.
Edited by user Friday, January 29, 2016 3:19:06 PM(UTC)
(103kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
No Problem. I'm having some other minor issues with the Beta. I'll make some videos and share those as well.
