solidtooldesigns
#1 Posted : Thursday, January 28, 2016 8:04:44 PM(UTC)
solidtooldesigns
Does ViaCad Pro support 2d igs curves ? I tried importing some that imported fine in rhino but didn't come through on Viacad.
via_blank.igs (32kb) downloaded 9 time(s).
#2 Posted : Thursday, January 28, 2016 8:45:19 PM(UTC)
ViaCAD Pro IGES supports curves. Can you send me an example file not working?
solidtooldesigns
#3 Posted : Friday, January 29, 2016 12:26:13 PM(UTC)
solidtooldesigns
Sorry I didn't know how to attach files and wound up attaching it to my last post.
#4 Posted : Friday, January 29, 2016 12:36:16 PM(UTC)
They are coming in as white. If you have a white background you might miss them as I first did.
Edited by user Friday, January 29, 2016 12:37:36 PM(UTC)  | Reason: Not specified
solidtooldesigns
#5 Posted : Friday, January 29, 2016 2:27:52 PM(UTC)
solidtooldesigns
They come in as two little lines. Attached is a PDF showing what it should be.
Untitled 1.pdf (59kb) downloaded 10 time(s).
#6 Posted : Friday, January 29, 2016 2:42:59 PM(UTC)
Ahh it's a polycurve! Using your example I was able to add support for this curve type (I explode into individual curves). The change will be in 1186 builds.
This impacts not just IGES, but other importers such as STEP, SolidWorks, SolidEdge, CATIA, NX, etc.
Many thanks for taking the time to post the example file.
Edited by user Friday, January 29, 2016 3:19:06 PM(UTC)  | Reason: Not specified
Screen Shot 2016-01-29 at 3.04.34 PM.png (103kb) downloaded 5 time(s).
solidtooldesigns
#7 Posted : Friday, January 29, 2016 4:10:32 PM(UTC)
solidtooldesigns
No Problem. I'm having some other minor issues with the Beta. I'll make some videos and share those as well.
