G2Art
#1 Posted : Thursday, January 7, 2016 1:07:57 PM(UTC)
G2Art
HI,
I'm trying to create a solid or surface along a path (in this case a spiral) with various cross sections along the path at different points (in this case a number of circles with different diameters).
I used the "guide skin surface" tool but the resulting surface does not closely follow the path. I have tried different options with this tool.
Is there a better way?
I'd like the path to be followed exactly.
Thanks.
G2Art attached the following image(s):
Screen Shot 2016-01-07 at 10.20.27 AM.jpg (62kb) downloaded 5 time(s).
Screen Shot 2016-01-07 at 10.21.15 AM.jpg (60kb) downloaded 5 time(s).
solardrifter
#2 Posted : Thursday, January 7, 2016 3:12:20 PM(UTC)
solardrifter
Hi Mark,
as far I know the guides must touch the section curves.
It might be easier to create a straight skin surface over different cross section curves, and bend this surface in a second step around the target path.
Tim made a video about the required steps: https://www.youtube.com/watch?v=wamstQxaI24
Regards,
George
solardrifter attached the following image(s):
variable dia on spiral.JPG (146kb) downloaded 12 time(s).
thanks 1 user thanked solardrifter for this useful post.
G2Art on 1/7/2016(UTC)
#3 Posted : Thursday, January 7, 2016 3:27:42 PM(UTC)
Correct
Good idea!
I've asked for this surface type several times from Spatial. I'll keep asking...
G2Art
#4 Posted : Thursday, January 7, 2016 6:28:02 PM(UTC)
G2Art
George,
Thanks - your tips are very helpful and the video was great.
I also noticed that the guides need to touch the section curves and tried it but that approach did not produce desired results. Perhaps some tweaking is also required.
But your bend surface idea will do the trick for me.
Mark
