Model to sheet showing blank
Thanks: 7 times Was thanked: 2 time(s) in 2 post(s)
When i convert a 3d solid object to MTS i cannot get any view if i choose phong or gouraud in the method tab the model to sheet opens up blank. Anybody have any ideas?
Hello Sounds like you are in 2d mode vs 3d mode when looking at model to sheet? What are you colors for objects and the background? Are the draw view boxes there? Which version and build are you using? What operation system are you using? Regards Jason
Hi Jason I drew it in 3d mode and selected to model to sheet which if i am correct does it not go to 2d for MTS. The background is white the object color is black , when i switch the method box to (precise curves slower) i get my drawing back. The draw boxes are there. I am using Shark LT build 1016. I have two installs one on Windows 10 and Windows 7 Thanks Jim
Thanks: 224 times Was thanked: 173 time(s) in 105 post(s)
Originally Posted by: Jimbl When i convert a 3d solid object to MTS i cannot get any view if i choose phong or gouraud in the method tab the model to sheet opens up blank. Anybody have any ideas?
Hi Jimbl,
It happens to me too for some of the views (not all) : enlarging the view makes it come back.
This old bug was solved a long time ago and for some reason it is back on the last beta build...
JL
Thanks jlb It weird i can start a new file make three different solid shapes of different sizes they all appear the way they should in the phong MTS. Then i make a solid with the lathe solid tool and two views show up (top and front) I then make a solid using a circle extrude solid, only top view shows up. What do you mean by enlarging the view, zoom in or change the scale?
Can you post the file after you do the MTS? Tim
Attached is the drawing with a MTS. Tim i have down loaded a trial version of LT v9 so far i like it. The glitch with the feet inches is no longer there in windows 10.I tried the model to sheet issue in v9 3 out of the 4 views are showing up.
When i upgraded Viacad version 6 to Shark Lt v8 i seemed to have a number of issues importing parts from the older version into Shark Lt. Am i correct in thinking there will no issues mixing parts from V8 into V9? I look forward to your reply
Thank Jim
I pick my file i am trying to upload open and then try and upload and nothing happens
Edited by user Saturday, January 9, 2016 7:55:01 AM(UTC)
| Reason: Cannot attach file
