Solid Modeling
Super Fine resolution is too super
Thanks: 30 times Was thanked: 42 time(s) in 36 post(s)
                I exported a car body in OBJ format at each of the resolutions and these are the results. Course = 636kb Medium = 673kb Fine = 792kb Very fine = 1,255kb Super fine = 24,813kb From the final quality test between very fine and super fine I would guess that super fine can be reduced by at least 50%. At that resolution it is next to useless in Shark as it builds up memory real fast and the system struggles with complicated parts, whereas at very fine the system has no issues.
                Hi Craig Try changing your definition of Super Fine with Preferences: Custom Resolutions : Super Fine : Facet Angle to 6.  The difference between Very Fine and Super Fine is 7 and 5 degrees. Tim
    Tim Olson  IMSI Design/Encore
                Originally Posted by: Tim Olson  Hi Craig Try changing your definition of Super Fine with Preferences: Custom Resolutions : Super Fine : Facet Angle to 6.  The difference between Very Fine and Super Fine is 7 and 5 degrees. Tim
Hi Tim, the default should be changed as many people will leave it as it is and not realise it is draining their resources.
                >> the default should be changed as many people will leave it as it is and not realise it is draining their resort
Yes.  But this would change all v9 files with super fine setting so I will need to understand why the two degrees is creating 23k extra data. Would it be possible to get the file?
Edited by user  Thursday, December 24, 2015 2:01:14 AM(UTC)
 | Reason: Not specified
                Originally Posted by: Tim Olson  >> the default should be changed as many people will leave it as it is and not realise it is draining their resort  Yes.  But this would change all v9 files with super fine setting so I will need to understand why the two degrees is creating 23k extra data. Would it be possible to get the file? Tim
Which is the best way to send a file of that size?
Thanks: 55 times Was thanked: 46 time(s) in 32 post(s)
                Hi guys.
I'm not sure if this is the same generator but I find the STL export very erratic
Edited by user  Saturday, December 26, 2015 8:01:51 PM(UTC)
(417kb) downloaded 22  time(s). You cannot  view/download attachments. Try to login or register.
Solid Modeling
