Convert a imported STL
Hi
is there a way to subtract an imported STL from a volumebody? I need the negativ form.
I tried to convert the STL to a volumebody but earned a error message > please have a look to the pictures
Horst
Edited by user Wednesday, December 2, 2015 5:41:07 AM(UTC)
(26kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
If you post the STL file, I'll see if PowerPack Pro can convert it and post the model. Tim
Thanks, it is attached ...
Horst
Scheibenritzel_st1300_v2.zip
(237kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 38 times Was thanked: 65 time(s) in 47 post(s)
Interesting part Horst,
I quickly put it through PowerPack Pro, and I used a reduce triangle, convert to quads & Mesh to Analytic conversion.
I reduced the triangle count a bit too much, and it became faceted, but it definitely was a solid, and I know Tim will do it better. :)
Mike
Edited by user Thursday, December 3, 2015 2:05:10 AM(UTC)
pcf-horst.sfx.zip
(1,008kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
macOS Sequoia - MacBook M1 Max 64GB 2TB SSD & external display - SharkCAD Pro v14.1.0 build 1654 macOS Tahoe - v16 beta
Many thanks, but Iam using ViaCAD Pro 9 and can't open sfx-fils from Shark. (Punch-file does'nt work? the computer is hanging) The wheel is part of Hondas motocycle ST 1300 windshield- elevator gear. @ Tim Olson The PowerPack for ViaCad Pro 9 is also able to convert this? Horst
>>and can't open sfx-fils from Shark. You can rename the extension to .vcp. >>The PowerPack for ViaCad Pro 9 is also able to convert this? PowerPack Pro is the same add-on for ViaCAD/Shark. Tim
Many thanks for the informations! Sincerly Horst
