Art Smith
#1 Posted : Tuesday, December 1, 2015 1:56:11 PM(UTC)
Art Smith
ideas or help creating an unusual solid is being sought. imagine a NACA airfoil section on a XY-plane and half of a different NACA section in a matching YZ-plane. the section in the XY-plane can be "skinned" using the half-section in the YZ-plane to form a low drag blister. after a little work transforming the surface to a solid and adding a tapered fillet around the perimeter, you'd have a very nice low speed fairing. the solid I need help creating is a similar fairing only the base surface is NOT flat but instead a curved surface with a constant radius. does Shark have the capability to map flat dimensioned/defined feature (ie: the NACA section coordinates) onto a curved surface OR the functionality to bend/wrap a solid about a defined axis?? or should I just get a copy of Excel out and do the coordinate transformations.....?
thanks in advance for any ideas or help creating the unusual solid!
Art
artesmith@earthlink.net
#2 Posted : Tuesday, December 1, 2015 5:19:58 PM(UTC)
There is a tool that bends a solid about an axis. You provide an axis, bend radius, bend angle.
Art Smith
#3 Posted : Tuesday, December 1, 2015 8:06:40 PM(UTC)
Art Smith
Tim-
OUTSTANDING; thanks for your post!!! where do I find the tool and the definitions for the three variables.
Art
thefro
#4 Posted : Wednesday, December 2, 2015 2:24:12 AM(UTC)
thefro
Hi Tim
i just have a quick question, what is the additional tool pallet?
Brian
#5 Posted : Wednesday, December 2, 2015 10:44:48 AM(UTC)
This is the bend tool located with the fillet/chamfer palette.
#6 Posted : Wednesday, December 2, 2015 10:47:11 AM(UTC)
That is AeroPack, an add-on sold by darcorporation that integrates with their aircraft analysis tools. I used it to create a naca airfoil.
Art Smith
#7 Posted : Wednesday, December 2, 2015 3:05:16 PM(UTC)
Art Smith
Tim-
one more question: how is bend radius defined for asymmetric sections (ie: a tapered triangular beam for discussion purposes)? ...geometric center??
Art
