G2Art
#1 Posted : Monday, November 23, 2015 4:50:50 PM(UTC)
G2Art
I have recurring problems with thickening surfaces from SubD meshes.
I have created a simple, non-joined, mesh and subdivided it to levels 1 and 2, then created NURB surfaces from them.
Neither surface will thicken to .1 inch thick solid.
Is there a way to prepare, or clean up, a mesh derived surface for reliable thickening? Or a way to prepare the mesh itself?
The ability to reliably thicken a surface into a solid is very important in my work.
A couple of explanatory images are a file are attached.
Mark
SubD exercises 3 - forum.sfx (357kb) downloaded 12 time(s).
G2Art attached the following image(s):
Error message when thickening surfaces.jpg (15kb) downloaded 8 time(s).
SubD mesh - surface will not thicken.jpg (89kb) downloaded 10 time(s).
mitchb
#2 Posted : Monday, November 23, 2015 6:24:25 PM(UTC)
mitchb
G2Art,
Try using the "Rebuild Surface" tool, then thicken.
Mitch
mitchb attached the following image(s):
Screen Shot 1.png (128kb) downloaded 8 time(s).
thanks 1 user thanked mitchb for this useful post.
G2Art on 11/23/2015(UTC)
G2Art
#3 Posted : Monday, November 23, 2015 8:25:55 PM(UTC)
G2Art
It worked great - thanks, Mitch!
#4 Posted : Tuesday, November 24, 2015 1:17:12 AM(UTC)
Mitch had a great idea regarding rebuilding the surface! If you also need G2 continuity across the seams, you might consider manually rebuilding with a cover with guides.
Edited by user Tuesday, November 24, 2015 1:19:03 AM(UTC)  | Reason: Not specified
subdG2.sfx (935kb) downloaded 11 time(s).
G2Art
#5 Posted : Tuesday, November 24, 2015 7:04:17 PM(UTC)
G2Art
Tim,
I definitely need continuity and your method of rebuilding the surface as a cover surface with guides worked great. Thanks.
I used the outside edge of the original surface for the cover and the actual seams of the surface as guides. It worked cleanly and the surface thickened without a problem - see the attached image.
Mark
Cover surface with seams as guides.jpg (45kb) downloaded 9 time(s).
