Subdivision Modeling
How to prepare a surface from a SubD mesh for thickening
I have recurring problems with thickening surfaces from SubD meshes.
I have created a simple, non-joined, mesh and subdivided it to levels 1 and 2, then created NURB surfaces from them.
Neither surface will thicken to .1 inch thick solid.
Is there a way to prepare, or clean up, a mesh derived surface for reliable thickening? Or a way to prepare the mesh itself?
The ability to reliably thicken a surface into a solid is very important in my work.
A couple of explanatory images are a file are attached.
Mark
SubD exercises 3 - forum.sfx
(357kb) downloaded 12 time(s). G2Art attached the following image(s):
(89kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 8 times Was thanked: 77 time(s) in 39 post(s)
G2Art,
Try using the "Rebuild Surface" tool, then thicken.
Mitch
mitchb attached the following image(s):
(128kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked mitchb for this useful post.
It worked great - thanks, Mitch!
Mitch had a great idea regarding rebuilding the surface! If you also need G2 continuity across the seams, you might consider manually rebuilding with a cover with guides.
Edited by user Tuesday, November 24, 2015 1:19:03 AM(UTC)
subdG2.sfx
(935kb) downloaded 11 time(s). Tim Olson attached the following image(s):
(155kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
Tim,
I definitely need continuity and your method of rebuilding the surface as a cover surface with guides worked great. Thanks.
I used the outside edge of the original surface for the cover and the actual seams of the surface as guides. It worked cleanly and the surface thickened without a problem - see the attached image.
Mark
(45kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
