2D Drafting
Strange printing of drawviews with model in gouraud(coloured)
An old question. My registration about 2 years ago seem to have vanished, but now I have registered again. Already then I had a question about printing a sheet with some drawviews with a part in gouraud. In my case in gray. On screen it looks fine. Printing the sheet goes wrong. The part in gouraud is completely out of shape and is completely out of the sheet. On the place of the part there is a gray smeer and the printing is very slow. When the part is otherwise visualised in e.g. polylines it prints fine. Although I first look for a solution around the printer etc.,the printer works fine. I have saved the file in V7-format and took it to my old PC with V7, and with V7 the printing works correct. And the sheet with the parts in gouraud are fine. Why is it that V9 does not print the drawviews with parts in gouraud ?
Yes I can confirm that the bug is in V9. I cannot get a good printout on paper from V9, but it is fine from V8, and V7.
I have attached scans of the issue.
(208kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Thanks, I did not know it was an already existing bug. So I don't have to look further for a solution. javg
>>Yes I can confirm that the bug is in V9. I cannot get a good printout on paper from V9, but it is fine from V8, and V7. Checking... Tim
Hi Jason Can you send me your example file? My quick tests printed fine. Tim
Emailed the file.
While you are looking- flatten the draw views and print again. The shaded view isometric does not print in the same location as its displayed.
ViaCAD Pro _y123 flat views.pdf
(77kb) downloaded 11 time(s). jdi000 attached the following image(s):
(36kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
Hi Jason We have not been able to repeat yet. I've tried on Windows 8 while Todd in tech support has tried Windows 10. It's strange that it works to PDF but not to paper printer as the app does not know the print device. We're still checking on steps to repeat... Tim
they don't pay, so no link :=)
Edited by user Friday, November 20, 2015 11:23:11 AM(UTC)
2D Drafting
