Suggestions
Differential scaling from Gripper
Differential scaling should be available from the gripper. There are yellow scaling handles on each axis, but they only do uniform scaling. Oversight? Technical difficulty?
Hi Murray Uncheck "Uniform Scaling" in the Inspector Settings dialog box. Tim
Thanks Tim. I suggest a toggle key between uniform and differential when the scale widget's being used. Uniform default and "D" key for differential?
Hi Murray You can assign a short cut to toggle the value via ShortCuts : Gripper : Uniform Scale Tim
Thanks again, Tim. I'm struggling with subD here, I'm not able to get mesh symmetry working either. How's that done? Ticking the box isn't doing anything for me.
Suggestions
