murray
#1 Posted : Friday, October 23, 2015 10:11:56 PM(UTC)
murray
Differential scaling should be available from the gripper. There are yellow scaling handles on each axis, but they only do uniform scaling. Oversight? Technical difficulty?
#2 Posted : Saturday, October 24, 2015 12:09:42 AM(UTC)
Hi Murray
Uncheck "Uniform Scaling" in the Inspector Settings dialog box.
murray
#3 Posted : Saturday, October 24, 2015 4:33:14 AM(UTC)
murray
Thanks Tim. I suggest a toggle key between uniform and differential when the scale widget's being used. Uniform default and "D" key for differential?
#4 Posted : Saturday, October 24, 2015 1:24:57 PM(UTC)
Hi Murray
You can assign a short cut to toggle the value via ShortCuts : Gripper : Uniform Scale
murray
#5 Posted : Saturday, October 24, 2015 6:26:53 PM(UTC)
murray
Thanks again, Tim. I'm struggling with subD here, I'm not able to get mesh symmetry working either. How's that done? Ticking the box isn't doing anything for me.
