How can I change the grain direction of different parts in a wood rendering? Are there any videos (I've looked but can't find anything so far)?
Hi Jim
It depends on the product and the type of material (image file or procedural wood). Do you have a example file?
Edited by user Tuesday, October 13, 2015 11:15:24 AM(UTC)
Here's a small sample file. I'm using the wood from the Render Library. It's a simple wood frame. The grain should go vertically, as it does, on the stiles. The rails should have the grain going horizontally.
Wood Grain Test.vcp
(16kb) downloaded 11 time(s). You cannot view/download attachments. Try to login or register.
I'd also like to be able to make it look more like wood.
Thanks: 190 times Was thanked: 163 time(s) in 112 post(s)
The wood grain can be rotated with the advanced render settings in the Inspector.
Right click on the horizontal board, and change the settings in TextureSpace.
(93kb) downloaded 25 time(s). You cannot view/download attachments. Try to login or register.
Thanks. So the X Plane turns the rendering to run along the X axis? Is the Z Plane the default?
I made a video today showing some ways to apply and create wood textures.
https://youtu.be/fuRD3R-AdHg Tim
