mlubrecht
#1 Posted : Sunday, October 11, 2015 2:16:49 PM(UTC)
mlubrecht
I just upgraded to ViaCAD 2D/3D v 9 with the PowerPack LT add on. I'm trying to work my way through the tutorial to make a spoon out of a block, using the mesh methods. Unfortunately, I can't seem to find the subdivision tool, even though I've zoomed in and paused the tuturial. I don't seem to have the tool out at the end of the mesh submenu.
I've selected my proto-spoon using the deep select tool, and have the gripper enabled. I'm sure I'm missing something, but it sure wasn't apparent in the tutorial.
Anyone care to point me in the right direction?
Thanks!
luk72
#2 Posted : Wednesday, January 27, 2016 9:46:06 AM(UTC)
luk72
hi.
if you have not this tool at the end of "mesh tool" ribbon, it means you work with viacad v8 with pp lt, no v9. When i upgrade my v8 to v9 i must do a new instalation of viacad, not just "upgrade" older version. You probably upgrade yours v8 version with a power pack lt plugin only - but impossible... You must try clear old installations of viacad ie. with revo uninstaller, and make new clear installation, may help.
luk72
Edited by user Wednesday, January 27, 2016 9:57:30 AM(UTC)  | Reason: Not specified
