David Carson
#1 Posted : Saturday, October 3, 2015 12:21:37 PM(UTC)
David Carson
I have a reference image that is 4096 pixels wide. (It covers an area 600' wide). When I bring it into ViaCAD whether through import or File/open the resolution is substantially reduced (looks like maybe 512 or 1024.) Is there any way to improve this?
zircon
#2 Posted : Monday, October 5, 2015 8:15:03 AM(UTC)
zircon
Japan
Same here. I'm working with a high resolution architectural drawing that, once imported to Shark FX, appears so fuzzy that I can't make out numbers or even lines spaced close to each other. I need to constantly refer to another copy of the drawing opened using OS X preview.
Also:
-imported PNG images appear completely black
-imported jpg images seem to partially/sporadically obscure lines in the drawing unless I set transparency on. (By the way a search of the help menu and user guide for "transparency" turns up no information regarding why this happens. I could also find no information in the program help regarding what the transparent background pixel tolerance setting does.)
MacBook Air (13-inch, Mid 2013)
1.7 GHz Intel Core i7
8 GB 1600 MHz DDR3
OSX 10.11.6(Japanese)
SharkCad Pro v10.0.0 (1335)
#3 Posted : Monday, October 5, 2015 9:25:17 AM(UTC)
Would it be possible to send me this PNG?
#4 Posted : Monday, October 5, 2015 12:38:31 PM(UTC)
Hi David
If you could send me the image I could debug. Since images are drawn to the screen using OpenGL, it might be size limits based on the video board.
David Carson
#5 Posted : Monday, October 5, 2015 6:14:26 PM(UTC)
David Carson
Image was 4K wide. I broke it into four quadrants and re-assembled in ViaCAD. Resolution is much better.
