gsjames
#1 Posted : Tuesday, September 22, 2015 3:53:35 PM(UTC)
gsjames
I have DOZENS of old files that are in the.vlm format that were done with very early versions of this software package. Well, things have changed so much that I can't open them with FX9.1 build 1162.
Any suggestions? I'd really like to recover them.
#2 Posted : Tuesday, September 22, 2015 4:06:40 PM(UTC)
Hi Gary
We removed the vellum translator when we stopped rebranding the product for Ashlar, which would be v4.
gsjames
#3 Posted : Tuesday, September 22, 2015 4:30:55 PM(UTC)
gsjames
Any suggestions on how to recover them?
L. Banasky
#4 Posted : Wednesday, September 23, 2015 3:20:41 AM(UTC)
L. Banasky
Was thanked: 158 time(s) in 108 post(s)
I use VM Workstation with XP to run older versions of many programs.
http://www.vmware.com/products/workstation/
I use Concepts Unlimited Ver. 2 to work with .vlm, as well as .cu files,
I have many older files and this works well.
posh.de
#5 Posted : Wednesday, September 23, 2015 8:13:17 AM(UTC)
posh.de
I could batch convert them with DraftBoard (formerly Vellum Pro) to the DWG format, just zip and mail them (max. 20mb) if desired.
btw, if looking for a virtualization solution, you may want go for the free 'VirtualBox' before buying 'VMware' or 'Parallels'.
Edited by user Thursday, September 24, 2015 9:33:01 AM(UTC)  | Reason: grammar
gsjames
#6 Posted : Friday, September 25, 2015 3:40:16 PM(UTC)
gsjames
Per Tim's suggestion, I downloaded CobaltShare (freeware). I had to rename the file extensions from .vlm to .vs, but after that I was able to open the old files and export them into a usable format.
Thanks for the help.
