I am being frustrated by my incapability to extract a single-entity surface from a 1696 pieces surface.
Here is my process that is not working:
1. Selected an empty layer to be target of anticipated kept solid
2. Selected "Subtract Solid" tool
3. Selected solid to subtract from
4. In Select Mask, deliberately selected the color corresponding ONLY to the joined surfaces surface
5. noticed "Ctrl" to retain subtracted part
6. clicked on the joined surfaces surface
7. Checked the target layer for new creation, and NO OBJECT IS THERE; no new objects created ANYWHERE
8. Checked undo, and undo indicates recent undoable item with: "undo subtract solid1"
9. Inspected the Concept Explorer; could not find the kept subtracted part
Where is the retained subtracted part?
This seems so simple to me: Use one or more surfaces, single or joined that behave as one, and use for reverse-Boolean-creating a new surface so i can discard the highly undesirable, 1696+counts joined-surfaces-surface. "Undesirable" is an absolute understatement. I am coming to the mind that the fewer extraneous parts in the model the better. I don't know that i should have to resort to Rhino or some other tool to create outside of ViaCAD Pro a part or surface that i can see in VC Pro and not manipulate in ViaCAD Pro. I am starting to feel that if i can SEE it i should be able to do fundamental things with it.
If i can see it in ViaCAD, and if i can select it, why cannot i convert it into a simplified surface down to 2 or 3 vice 1696 faces? Upon simplifying the object, i get:
Attempt to simply the part.
Simplify Results
! Examined 1696 faces.
Converted 0 NURBS faces to 0 analytics.
OK.
I tried the "offset surface" tool. It provided nothing i expected.
What am i doing wrong (other than having a misinformed expectation)?
Please note: this problem i am having is an extension or another take on a previous problem. As i understood from the forum reply, ViaCAD's specialty is not in breaking down mesh surfaces from other tools into something that can be used for cutting surfaces in ViaCAD, or something to that effect.
But, this is a fundamental, crucial, undeniable impact on what i need to do. Ultimately, i may have to go back to the original mesh, break it down again, then every-so-many-feet of multiple surfaces join those until i get through all ~500 feet of surface that is too curvy and complex to sweep from the bottom centerline up to the 1-foot waterline.
Thanks for any input!
As for the attached .vcp files, the 1.32 mb file has the joined surfaces as one join made of the 1696 surfaces. the -a file, which is 375.9 kb, has 4 surfaces, color-coded to help anyone wishing to play with it not have to guess at breakdown points i might need or want.
Please, try not to supply me surfaces made OUTSIDE of VCP or VC 2D/3D. I need to learn or be told how to do this IN VCP.
Also, I tried in Shark Beta 7, build 921, and cannot yet determine if what i am attempting is even possible there, either. But, in both VCP 6 and Shark Beta 7, i CAN subtract the surface from the solid. What i tried to do but cannot figure out is how to reverse Boolean the solid, or keep the cut out piece and discard the larger portion.
Thanks!
mesh-surf-subtraction-tests-a.vcp
(376kb) downloaded 5 time(s).
mesh-surf-subtraction-tests.vcp
(1,355kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
