dougw
#1 Posted : Wednesday, September 2, 2015 6:43:09 PM(UTC)
dougw
I have unintentionally rotated my model out of position in all three axes.
How can I realign my model, or relocate the origin, to be correct for the
normal planes?
All the Best,
Doug White
#2 Posted : Thursday, September 3, 2015 3:10:01 PM(UTC)
Hi Doug
I think you can do this with the translate and 3 Point rotation tools. Use the translate to position the origin. Then use the 3 point rotation tool twice to align two axis.
Video
https://youtu.be/1GLF2LYvrMA
Edited by user Thursday, September 3, 2015 4:23:57 PM(UTC)  | Reason: Not specified
macnavi
#3 Posted : Friday, September 4, 2015 2:57:14 AM(UTC)
macnavi
Netherlands
There is a downside to this, which can cause big problems when you keep on working on the part after changing the origin: When you do this with a unified solid, that if you would remove the unification (Concept Explorer->Features->remove Union), all separate solids will jump back to the place they were before they were unified, except for the solid that was selected for translation.
I would actually classify this behaviour as a bug, as I don't see the reason why someone would want this. Or is it intentional?
Guest (7)
