Jimbl
#1 Posted : Monday, August 3, 2015 11:20:12 AM(UTC)
Jimbl
I dont know whether i toggled something on or not. Recently in 2d or 3d if i make a 2d drawing and use model to sheet the drawing appears in model to sheet and it also appears on the screen in larger view. When i check my layers it is no longer in the original layer it has moved to MTS layer if i copy paste it back to the original layer and delete from MTS layer it disappears from MTS drawing. Any ideas?
Thanks Jim
#2 Posted : Tuesday, August 4, 2015 8:04:29 AM(UTC)
Hi Jim
When the model to sheet is built the original geometry stays on the layer is was on. New model to sheet layers are built and the drawing views are built referencing the original geometry. The layer visibility is turned off, so you only see the model to sheet layers. You can toggle the layer visibility on/off to see the geometry. Maybe you can post a sample file.
Jimbl
#3 Posted : Thursday, August 6, 2015 6:21:16 PM(UTC)
Jimbl
When i get back to work i will see if i can post something. I looked in CE the layer the original geometry was in was not toggled on. I toggled it on and toggled MTS off, no geometry in the original layer.
Thanks Jim
