Suggestions
Split will duplicate cutting block
Thanks: 13 times Was thanked: 13 time(s) in 10 post(s)
When I use a solid block to split another solid, in v9 it will duplicate the block. In the video you will see that I'm first hiding and showing the block I'm using to cut, then I split the item, then after the split you can see it has created two blocks. Only the second one is linked to the cut, the first one not. Interesting enough, the extra block is now in the colour of the solid that has been cut. This did not happen in v8.
https://youtu.be/EXfA8IwDatk
Edited by user Saturday, July 25, 2015 9:54:05 AM(UTC)
hi, i can repeat this in build 1163, in concept explorer you can easily see the duplication. probably a bug.
1 user thanked rokoko for this useful post.
Suggestions
