Pobble
#1 Posted : Wednesday, July 15, 2015 4:18:35 AM(UTC)
Pobble
Hi
New to Viacad 9 and I am starting to plan a new layout for our shop.
I have the outside walls set up and I am not trying to insert sliding doors.
Seen the tutorial and tried it, but keep getting the error message 'Not enough space for wall feature'
I cannot work out what I am doing wrong. The wall is 45 metres long and the dorr is 8 metres along.
I have tried changing the thickness of the walls, but no joy.
What am I doing wrong?
Brian
#2 Posted : Wednesday, July 15, 2015 6:01:52 AM(UTC)
Originally Posted by: Pobble Go to Quoted Post
Hi
Brian
Brian
Could you possibly have extra walls drawn on top of one another. That message is when the wall you picked to add the door is less than the door length. Or are you adding the door near another wall say in a corner and the swing 8m of the door would interfere with the wall?
Try drawing somewhere off to the side of your current drawing a new single wall 45 m and then try to add the door.
Pobble
#3 Posted : Wednesday, July 15, 2015 8:10:52 AM(UTC)
Pobble
Thanks Jason.
I checked and do not have a wall on top of another.
Also made a new 45 metre wall and tried to insert all types of door, but still get the same error.
Brian
#4 Posted : Wednesday, July 15, 2015 8:26:24 AM(UTC)
Brian
What build of the program are you running its in the help about (build #)? Which version of ViaCAD are you using? Can you post a screenshot of the wall setting you are using. Can you place a door if its smaller in size like 1 m?
Pobble
#5 Posted : Wednesday, July 15, 2015 9:01:51 AM(UTC)
Pobble
Thanks Jason
Build 1109 Viacad 3D 2D 9.
I tried a 1m door and the same error.
I have attached 2 screenshots of the wall and door settings.
What does the offset do when putting in a window?
Brian
Pobble attached the following image(s):
#6 Posted : Wednesday, July 15, 2015 9:33:19 AM(UTC)
Brian
The offset is the distance the feature is placed from ref wall. See pics. When you are clicking on the wall location to add the door are you too close to the corner?
Pobble
#7 Posted : Wednesday, July 15, 2015 9:51:36 AM(UTC)
Pobble
Thanks Jason
I am in the middle of the wall and have also tried various places.
When I click on the position i want the door nothing happens. I then move further along and click aghain and the error comes up.
Looking at the tutorial video you set the width and click where you want it. A door is then put in and you can adjust it.
I cannot get this to happen.
Brian
Shop Layout1.vc3 (13kb) downloaded 10 time(s).
#8 Posted : Wednesday, July 15, 2015 11:25:20 AM(UTC)
Brian
I added the door and reattached the file. I believe that this was fixed in a newer version, as I could not get it to work in version 1109 either. I export the file as V8 so try that
Edited by user Wednesday, July 15, 2015 11:28:43 AM(UTC)  | Reason: Not specified
Shop%20Layout1_dooraddedV8.vcp (13kb) downloaded 7 time(s).
Pobble
#9 Posted : Wednesday, July 15, 2015 11:38:09 AM(UTC)
Pobble
Thanks Jason
As I still have the latest version and not V8 I still cannot get it to work on your file.
Brian
Pobble
#10 Posted : Wednesday, July 15, 2015 12:05:41 PM(UTC)
Pobble
Hi Jason
In your last post you mention that you thought this was fixed in a newer version, but when I check I am told I have the latest version.
How can I get a version that works?.
Brian
#11 Posted : Wednesday, July 15, 2015 12:17:42 PM(UTC)
Brian
Sorry I meant to say it works on the newer build of V9 (newer than 1109) see this post
http://forum.punchcad.co...sts&t=7270#post27118
You can contact support.
http://support.encore.co...frm.aspx?product_id=2820
Pobble on 7/15/2015(UTC)
#12 Posted : Wednesday, July 15, 2015 1:30:39 PM(UTC)
Hi Brian
I would suggest using the link Jason provided and ask Encore Technical Support for the "ViaCAD 2D3D 9 SP1 pre release" to solve some issues with inserting wall features.
Pobble
#13 Posted : Wednesday, July 15, 2015 3:16:50 PM(UTC)
Pobble
Thanks Tim
I have already followed Jason's link to support and await their reply.
Brian
