dougw
#1 Posted : Friday, July 3, 2015 9:09:18 AM(UTC)
dougw
Back in May I upgraded from ViaCAD 2D/3D V8 to V9.
V8 allowed me to dimension features in the individual views
after doing a model to sheet. I can't seem to do this now.
I can click and select the origin point of the part in
the view but cannot snap to any other vertex, end of line,
center, or mid-point to complete the dimension. I have the
same issue drawing lines too. Except for the origin I
cannot snap to any other point.
Any ideas?
Running Windows 7 Pro 64 bit.
Update, I opened the Bracket.vc3 example file, did a model
to sheet. Everything works fine however I cannot get this to
work on anything I create.
All the Best,
Doug W.
Edited by user Friday, July 3, 2015 10:32:21 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, July 3, 2015 12:38:35 PM(UTC)
Hi Doug
The items you create are these using model to sheet or items you add to an existing draw view.
Also, what is your build number?
dougw
#3 Posted : Friday, July 3, 2015 1:38:59 PM(UTC)
dougw
Hi Doug
Thanks for the quick reply!
These are items I create using model to sheet.
Version 9.0.0 Build 1109
All the Best,
Doug W.
Edited by user Friday, July 3, 2015 3:01:14 PM(UTC)  | Reason: Not specified
dougw
#4 Posted : Friday, July 3, 2015 2:56:43 PM(UTC)
dougw
Smart Dimension won't even find the origin point. I have to select
vertical or horizontal to get it.
All the Best,
D. White
#5 Posted : Friday, July 3, 2015 2:56:50 PM(UTC)
Hi Doug
I will private email you links this weekend to the upcoming service pack for ViaCAD 2D3D 9 Win. I'd like to see if it is fixed in a more current build.
dougw
#6 Posted : Friday, July 3, 2015 3:20:04 PM(UTC)
dougw
Hi Doug
Thank you! I'll let you know if it works!
All the Best,
D. White
dwhite53
#7 Posted : Saturday, July 4, 2015 9:09:37 AM(UTC)
dwhite53
Somehow I have two user accounts.
Here's a little more information.
I have my model displayed as a wire frame. It is displayed in a top view.
I do a model to sheet by window selecting the objects to create the sheet
from. I cannot dimension inside the views on the sheet.
If I have my model displayed as a solid and displayed in a top view I can do
a model to sheet by clicking on the top surface. I can then dimension in the
views created on the sheet.
All the Best,
D. White
