rokoko
#1 Posted : Sunday, June 21, 2015 12:45:55 PM(UTC)
rokoko
Was thanked: 57 time(s) in 45 post(s)
hi,
i am unable to subtract the blue "+" solid from the selected part in my model (see picture).
after the subtract solid command the blue + disappears and does not result in an imprinting + sign.
is it a bug? thanks for help
build 1161
edit: meanwhile i tried the operation in version 8 (german). amusingly the subtraction failed on first try, but after an undo it worked on the second try. but only in version 8. in version 9 no go.
Edited by user Sunday, June 21, 2015 1:53:04 PM(UTC)  | Reason: Not specified
VenueTest.vcp (135kb) downloaded 9 time(s).
David Gross
#2 Posted : Sunday, June 21, 2015 4:15:52 PM(UTC)
David Gross
Try doing a compact file with remove history checked.
David Gross
Dmg Design
Colgate, Wi.
rokoko
#3 Posted : Sunday, June 21, 2015 10:04:42 PM(UTC)
rokoko
hi,
thank you for the tip. unfortunately this did not solve the issue. after compact file my associations are gone, but the problem still exists.
#4 Posted : Monday, June 22, 2015 1:26:33 AM(UTC)
Try a stitch solid command on the solid, this worked for me. This will run a bunch of repair procedures on the solid if it is already a solid plus add it as a feature operation.
I need to jump into the debugger why this is not subtracting as the part appears aok.
rokoko on 6/22/2015(UTC)
rokoko
#5 Posted : Monday, June 22, 2015 11:03:06 AM(UTC)
rokoko
hi,
thank you very much! a stitch solid on the black part solved the problem. this was something new for me to learn.
