circuit7
#1 Posted : Friday, May 29, 2015 9:59:51 PM(UTC)
circuit7
If I draw a randomly spaced set of circles in Viacad 9...is there a way to export the locations of the center points as text locations "x,y"
In some cases I don't want to use a CAM program, I'd rather have a list of the x,y points and use them to write G code by hand....
rockyroad_us
#2 Posted : Saturday, May 30, 2015 4:43:07 PM(UTC)
rockyroad_us
I figured I try this but no go. Under the Verify Menu there's a properties command that brings out an ascii option but that doesn't work with mines as nothing gets saved. I'm on a mac running sharkfx. I believe that same command is in viacad.
There's also a check objects under verify menu which brings up a save as button but the file created is empty. I'm not sure what is supposed to save when you hit save as.
Tim can you verify this.
#3 Posted : Saturday, May 30, 2015 9:42:28 PM(UTC)
Try the Area 2D Data Set from the Windows :Attributes and BOM Tool. Then do a Export BOM. This resulting text file will contain the x, y CG which is the center of a circle.
Edited by user Saturday, May 30, 2015 9:44:16 PM(UTC)  | Reason: Not specified
murray
#4 Posted : Saturday, May 30, 2015 10:04:14 PM(UTC)
murray
dxf files are quite readable for this opened in a text editor. You've got x,y cords of the centre and the radius, not too hard to make it out.
#5 Posted : Saturday, May 30, 2015 10:49:23 PM(UTC)
Yup! If this is a top view (no transform used) you can search for Circle where the codes:
10 = x
20 = y
30 = z
40 = radius
