Solid Modeling
Generating gcode from stp or step export
                Just curious, what program does a good job generating gcode from exported (stp or step) files?  I see CamBam, and a few others, but I'd like to hear from someone who has actually had success in  gcode generation. Thanks, DanL
                Hello DanL I must have the GCode for printing with a 3d printer. For this exist various slicers. A good freeware is slic3r (comes with repetier). A bit more happy I am with the slicer from MatterControl. A goo work I have with Simlify3D but this is not free. All this programs makes GCode, but all in a bit different way. Is what you searched? Regards Roger
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
                mastercam if you are doing more than waterline code is the bar by which others are judged.  I have not yet tried autodesk labs cam on a machine yet, but it has ability to work with dwg (obviously) in a smooth solid interface opposed to stl triangles - and free!
                I'm still learning how to use my desktop CNC, a Carbide3D Nomad 883. The CAM software that is included with it is MeshCAM. It creates g-code for CNC machines, but I'm not sure if that code would work for 3D printing.
                Actually, my question went to CNC, not additive processes. I'm thinking a lot of detail would be needed for specific gcode generation, i.e., toolbit type, diameter, feed and rotation rates, type of controller. Not an easy answer for this one, I fear. DanL
Solid Modeling
