Solid Modeling
Viacad 9 pro - One rail sweep solid tool
                Hi All, I just bought Viacad 9 pro for Windows 8.1 pro and I realized that the "One rail sweep solid tool" is not working, am I the only one facing this problem or it is a bug?. Thank you, David Turpin
                Hi David, Works for me. Try this. Draw a circle in isometric view and a line next to it. Make the line perpendicular to the plane of the circle. Then click one rail sweep solid, click on the circle, then click on the line. I bought ViaCAD Pro about a week ago, so I'm just a little ahead of you, quite a learning curve. Mark
Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
                Hi David,
It works for me too. WIN 7, 64-bit. VIACAD PRO V9 Build 1109.
Are you getting any error messages or is the icon just unresponsive?
Try it from the Menu instead of the icon (or vice-versa).
Did Mark's suggestion above work for you?
The Other Tim
Edited by user  Thursday, May 14, 2015 8:20:17 AM(UTC)
 | Reason: Not specified
WaveMechanic attached the following image(s):
(15kb) downloaded 11  time(s). You cannot  view/download attachments. Try to login or register.
    Tim (NOT Tim Olson) ViaCAD 2D/3D and PRO V9 1184, Blender 2.49-2.78. Win 7 SP1, Core I5, 64-bit, NVIDIA G105M
                Hi Tim and Mark, Thanks a lot for your help, it was my mistake... :( It is working fine now, I was not selecting the right option. Best regards, David
Solid Modeling
