Mark_S
#1 Posted : Tuesday, May 12, 2015 4:55:31 PM(UTC)
Mark_S
Howdy, Thanks for reading this. Another newbie question. I want to make a box with a curved bottom so that is will fit on a cylinder. File attached. Almost have what I want but when I delete the circle the bottom of the box disappears. How do I get rid of the circle? Or am I going about this the wrong way.
Thanks in advance!
Mark
bottom_housing.vcp (206kb) downloaded 11 time(s).
rockyroad_us
#2 Posted : Tuesday, May 12, 2015 5:34:08 PM(UTC)
rockyroad_us
use the command hide. It will get rid of it from the screen. If you deleted it, the dependency will delete too. It should prompt you before that. Read the message.
thanks 1 user thanked rockyroad_us for this useful post.
Mark_S on 5/12/2015(UTC)
Mark_S
#3 Posted : Tuesday, May 12, 2015 5:46:03 PM(UTC)
Mark_S
Thanks rockyroad_us! Did not know about the "Hide" command. BTW, I don't get a message about dependency, although I have seen it in other situations.
Cheers,
Mark
