#1 Posted : Sunday, May 10, 2015 1:38:16 PM(UTC)
Hi All
I just sent out an email to everyone who purchased the ViaCAD Tips, Tricks, and Techniques E-Book with links to an update. The update adds 30+ new tips to the book plus includes some suggestions from the readers.
This update is free to everyone who purchased the E-Book from MasterViaCAD or Encore. If you purchased the hard cover version from Amazon, you are welcome to a courtesy E-Book update as well.
Also be sure to let me know what types of tips you may like to see added in the next update.
Contact me by private email if you need the update.
30+ New Tips Added
Can I assign default Inspector settings from an object?
Can I thicken a collection of open surfaces?
How do I calculate the section properties from a solid tube?
How do I calculate the Moment of Inertia for a cross section?
What are Iso Lines?
Is it possible to rotate the WorkPlane?
What Shortcuts exist for the Gripper?
Can I specify the Gripper Location for an object?
Can I assign a Shortcut to toggle the Inspector on/off?
Can I use a point entity as a guide curve?
Why is my Environment Map not working?
Why does my part disappear in different views?
Why does a part name appear to change?
What types of intersections does ViaCAD support?
How can I make user defined pen styles, layers, and views available for new drawings?
Can I suspend Associativity?
What Happened to Line Weights Exported to AutoCAD?
How can I delete all objects in a Layer?
Is it posible to change the default light intensity?
How can I convert an object with NURBS to Analytic surfaces?
Can I open a PhotoShop/EPS/PDF file?
Can I create a custom dimension type?
How do Dimensions behave inside Draw Views?
Can I change the coordinate system of the data entry area?
Can I export to PDF?
Where can I find a title block?
Is it possible to snap to faces in the Push/Pull tool?
Why does the application change the basic colors at Launch on Windows?
Can I scale the size of a fill pattern?
How do I convert a filled polygon to a hatch entity?
What does “illegal alignment face” mean with the Insert Face tool?
Does Push/Pull recognize curves outside the major views?
How can I create a new layer for selected entities?
Is there a way to quickly pick the Select tool?
Why are my objects not appearing transparent?
What is the coordinate system used in ViaCAD?
Edited by user Sunday, May 10, 2015 1:41:34 PM(UTC)  | Reason: Not specified
