Redlion
#1 Posted : Friday, April 17, 2015 11:24:30 AM(UTC)
Redlion
Hi all I'm new to this forum and to using ViaCAD. I love the software thus far find it easy to use, however Iran into a snag when trying to extrude a tire and add tread around a curve. Are their any tutorials to do this?
Thanks Again,
Brian
TireTest1.vcp (67kb) downloaded 11 time(s).
Redlion attached the following image(s):
Screen Shot 2015-04-17 at 1.16.33 PM.jpg (106kb) downloaded 24 time(s).
#2 Posted : Monday, April 20, 2015 3:15:13 PM(UTC)
You're going to have to work out your own method. One possibility would be to create a strip with the tread pattern as a repetitive protrusion , bend it into a hoop and subtract a revolved shape to give the rounded profile.
Redlion
#3 Posted : Monday, April 20, 2015 9:32:45 PM(UTC)
Redlion
I Figured it out. The initial drawing I did wasn't connected properly. This is a sample of what I was able to achieve. Using the polar duplicate with the center point of the rim was how I was bale to reproduce and space evenly the thread pattern. No I will be able to produce a more complicated pattern accurately.
Screen Shot 2015-04-20 at 11.25.32 PM.png (258kb) downloaded 16 time(s).
Screen Shot 2015-04-20 at 11.09.04 PM.png (213kb) downloaded 29 time(s).
#4 Posted : Tuesday, April 21, 2015 12:30:41 AM(UTC)
Awesome!
