dtest
#1 Posted : Monday, March 16, 2015 8:48:10 PM(UTC)
dtest
I'm trying to define a part with the user defined mass property.
It has a density of 0.16 g/CC. (Balsa-wood)
When I click OK, and then go back in to look, its set to 160.00 g/CC
If I chose a predefined material it works.
Is there a way to create my own materials?
TIA,
Dave
(Shark FX v7)
#2 Posted : Monday, March 16, 2015 11:38:29 PM(UTC)
Hi Dave
Look at the Materials.ini file in the Environ folder. You can add your own materials using this file.
