Import/Export
how to change a still file into a solid ?
Thanks: 16 times Was thanked: 4 time(s) in 4 post(s)
hello, i do have an .stl file and would like to work with it. what is the best way to change the object ? I tried, to change into solid, it is not working, only the beachball is running for hours. thank you for any help Andreas
The Edit: Change Object Type uses the standard stitcher and has limits.
I am creating an add-on to ViaCAD that adds another stitcher (from IntegrityWare) and options to simplify if possible.
http://www.masterviacad....ckPro/page20/page20.html If you can zip and send me your file, I'll see how well it works.
thank you Tim, how do i add the file into the post ? Andreas
Hello Andreas
In the lower left corner is an "Attach files to this post?" check box.
(46kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
Originally Posted by: Tim Olson Hello Andreas In the lower left corner is an "Attach files to this post?" check box. Tim
Thank you, Tim
eichhoernchen.stl.zip
(3,886kb) downloaded 7 time(s). You cannot view/download attachments. Try to login or register.
Hello Andreas
Based on the organic shape of the file, I decided to use the SubD to NURB tool in PowerPack.
But since it was all unstructured triangles, I first used 3D-Coat's auto topo command to convert into quads. For a file such this, you will need to remesh.
Once converted, I was able to create a nice water tight NURB solid.
Below is a link to the resulting ViaCAD file. (99994 triangles ->63482 quads ->764 NURB face solid)
http://www.csi-concepts.com/Demo/misc/chip.zip Tim
Edited by user Tuesday, March 17, 2015 4:14:41 PM(UTC)
(226kb) downloaded 24 time(s). You cannot view/download attachments. Try to login or register.
Hello Tim, thank you very, very much ! one last question: could you send me the link for downloading / buying the PowerPack. I can only find the site, where all the features are listed. Andreas
Hi Andreas >>> buying the PowerPack. On Friday Encore approved a variety of PowerPack Beta promotions which I should be sending out next week. Tim
i will look for the Beta PowerPack and thank you for your friendly work to change my .stl file :-) i say good night now , here in germany. have a nice day. Andreas
Hi Tim. I have a PNG. FILE of an image that I want to import into VIACAD. I am able to doso, but how do I attach the image onto the top of my material of 3"x3"x1.5" in VIACAD? I want to attach it to the top, then extrude the image so that I can sink it into my material, so that I can machine that image shape into my material, for example; like if I were to machine a logo in aluminum.
ViaCAD does not have a tool that converts an image into 3D. Some possible options for you:
• Read the image into ViaCAD and trace over with curves as a basis for your 3d model
http://www.csi-concepts.com/Demo/videos/Tracing.mp4 • Try one of the free scan to dxf apps to get outlines which you can extrude
• If it is an Illustrator file, convert to paths and export as in the tutorial below
http://www.csi-concepts....tutorials/AITutorial.pdf Good luck!
Import/Export
