Lew Stivers
#1 Posted : Sunday, March 15, 2015 4:15:12 PM(UTC)
Lew Stivers
I purchased two ViaCADs for Mac, one for my office and the other for my home. I have been trying to learn how to use them by working primarily at home. Now I find the Default Pen and Default Fill color palettes are corrupted(a white shows to be white, but is gray and a gray shows to be green and is green), apparently by me, at home. So far I have not caused any damage to the program at work.
Question: How can I repair the palettes at home or copy them from the program at work and replace the ones at home?
Also, as a thought, What did I likely do to cause this problem, so I can try not to repeat?
Thanks.
#2 Posted : Monday, March 16, 2015 10:51:34 AM(UTC)
Hi Lew
You can reset your settings from the dialog Preferences: Factory All:
Or you can delete this file which contains your default pen colors :
/Users/<username>/Library/Application Support/com.encore.viacad3dv9/VC3Prefs.ini
You should also be able to copy this file from one machine to another.
